PM8000 !!! Symbols on Ethernet Setup screen
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • PM8000 !!! Symbols on Ethernet Setup screen
Charles_Murison
Charles_Murison Champion
566
Mehran_Mehrnia
Mehran_Mehrnia Champion
195
Ramasamy_N
Ramasamy_N Champion
115
Andy_Hubert
Andy_Hubert Contributor
Contributor
Posted: ‎2017-11-09 02:01 AM
1785
I have a coleague here in the UK who has recently set up a PM8000 IP address.
The IP adress is Unique on the network, but the !! symbols will not go away.
Has anyone any idea of how we get around this?
Andy
Posted: ‎2017-11-14 11:27 AM
Hi Andrew,
Your photo shows a PM5500 meter.  If this is the case, then it is normal behavior for the IP address to have the exclamation symbols appear.  It means that either the meter has not completed writing the address that it received from the DHCP server, there is a problem with the DHCP server, or there is a problem with the static IP address that was entered (perhaps wrong subnet or gateway info).
Normally, if you navigate out of the setup screen then back in again, the exclamation symbols disappear (assuming the IP address is valid).  For really old PM5500 firmware, a reboot might be required.
Hope this helps.
Cesar
Hi Andrew,
Hope this helps.
Cesar
JamesAZZO
JamesAZZO
Leader
Posted: ‎2017-11-20 04:35 AM
You have to admit - although expected behavior, it is very disconcerting when you first see this.
