PM8000 Frequency resolution
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • PM8000 Frequency resolution
Charles_Murison
Charles_Murison Champion
566
Mehran_Mehrnia
Mehran_Mehrnia Champion
194
Ramasamy_N
Ramasamy_N Champion
115
Posted: ‎2022-08-28 06:10 PM
3638
Hi All,
I am trying to determine if the PM8000 meets the requirements of the AEMO Mareket Ancillary Service Specificaiton Verion 7.1 in terms of Frequency resolution for Fast FCAS? Table 4 in 5.3.2
https://aemo.com.au/-/media/files/stakeholder_consultation/consultations/nem-consultations/2021/mass...
As per the attached screen shot the frequency resolution required is <= 0.0025Hz (2.5mHz) for Fast FCAS.
If it does not is there a Schneider meter that does?
  • PM8000
DanL
DanL Champion
Champion
Posted: ‎2022-08-29 09:47 AM
2
3617
Yes, the frequency registers have better than 2.5mHz precision on the PM8000 (when read or recorded in Float32 format).
The PM8000 uses a 40MHz clock to measure the periods of the zero crossings of the fundamental voltage.
Model ION Module ION Register Measurement window Update period Standard Compliance Claimed Accuracy Precision
PM8000 Power Quality Aggregator Power Frequency 10 s 10 s
IEC61000-4-30
Class S*
+/-10mHz
< 0.01mHz
(7 digits)
PM8000 Power Meter Module Freq 1 s 1 s
IEC61557-12
CL,02
+/-0.02% = +/-10mHz
< 0.01mHz
(7 digits)
PM8000 HS Power Meter Module HS Freq 1 cycle 1/2 cycle
< 0.1mHz
(6 digits)
Replies 6
DanL
DanL Champion
Champion
2
3618
IEC61000-4-30
Class S*
+/-10mHz
< 0.01mHz
(7 digits)
IEC61557-12
CL,02
+/-0.02% = +/-10mHz
< 0.01mHz
(7 digits)
< 0.1mHz
(6 digits)
Posted: ‎2022-08-29 03:58 PM
3609
Hi Dan,
Thanks for that. Just what I needed.
I was wondering where you sourced the information from? Is there any official Schneider documentation with that written down?
I will likely need to show the client that the meter satifies the requirement. If it is not in official documentation an email from local Schneider team will hopefully suffice.
Thanks again.
Charles_Murison
Champion
Posted: ‎2022-08-30 09:37 AM
Hello @Anonymous user
Standard Compliance and Claimed Accuracy can be found in the technical datasheet
https://www.se.com/ca/en/download/document/PLSED310058EN_Web/
Charles
Kamal_Kant
Kamal_Kant Explorer
Explorer
Posted: ‎2025-07-23 12:22 AM
1257
Hello Dan and Charles,
Thank you for your responses.
I’m also looking for a supporting document to share with our customer in Australia. I tried accessing the details through the link you previously provided, but it appears to no longer be valid. Could you please assist with an updated link or share the relevant document directly?
Thank you in advance.
Best regards,
Kamal Kant
Charles_Murison
Champion
Posted: ‎2025-07-23 11:06 AM
1
1252
Hello @Kamal_Kant ,
https://download.schneider-electric.com/files?p_Doc_Ref=PLSED310058EN&p_enDocType=Other+technical+gu... is a link that works for me. Another option would be to go to se.com and search for "PLSED310058EN" (without quotes).
Charles
Kamal_Kant
Kamal_Kant Explorer
Explorer
Posted: ‎2025-07-23 04:10 PM
Hi Charles,
Thank you for the new link, it works.
Best Regards,
Kamal Kant
