【PM8000】Frequency of synchronization with NTP server
Metering & Power Quality
Send InviteCancel
Metering Setup - Nameplate Info FAC1 DeviceType 8000 FAC1 Revision 003.000.001 FAC1 Feature Set Standard FAC1 Template 8000_V2.2.0.0.0
Advanced Ethernet - NTP CL1 Enable NTP Time Sync NTP CL1 NTP Time Sync Interval 1 day CL1 Event Logging Threshold 0.02 ETH1 NTP Server 192.168.100.240 CL1 Time Sync Type UTC CL1 Time Sync Source ETHERNET Time Sync Count 0 Time Since Sync/Reset 19273003
2022-06-3009:38 AM
The unfortunately named "CL1 NTP Time Sync Interval" can only configure SNTP time sync intervals (not NTP).
Be sure to configure the "CL1 Clock Source" to "Internal" ("COMM" is also acceptable as with NTP enabled it will behave as "Internal"). Never use an external time sync source with the Clock Source configured to "Line Freq".
If you continue to have issues, please contact support for additional troubleshooting steps.
2022-06-3009:38 AM
