PM8000 Failed Firmware Update
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM8000 Failed Firmware Update
Charles_Murison
Picard Charles_Murison Picard
526
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
138
Ramasamy_N
Captain Ramasamy_N Captain
115
mjr5097
Crewman mjr5097
Crewman
Posted: ‎2024-08-23 10:26 AM
1222
I was updating the firmware on a PM8000 device and got a message saying "meter communication issue".  ION Setup then crashed.  The display now fails to connect to the meter and I can't reach the device on ION Setup.
Here are the installation logs.  Any help would be appreciated!
9:37:20 AM: Software Version (Build): 3.2 (Build 23305)
9:37:48 AM: Processing file: PM8000_V004.005.000.upx
9:37:48 AM: Upgrade started at Friday, August 23, 2024 9:37:48 AM
9:37:48 AM: Device Name = 78-1R
9:37:48 AM: Device Serial Number = ME-2110A177-02
9:37:48 AM: Device IP Address = xx/7700
9:37:48 AM: Device IPv6 Link Local = fe80::260:78ff:fe11:6f2c
9:37:48 AM: Device Firmware = 003.000.000
9:37:48 AM: Upgrade Power Cycles = 0
9:37:48 AM: Upgrade Filename: PM8000_V004.005.000.upx
9:37:48 AM: SHA256: 1617EEB9B2675A3C0721275B58AB9126B1A32D1303CC5BCA6D46D53FE85CA581
9:37:48 AM: Proceeding with firmware download
9:37:48 AM: Transmit delay: 0 ms
9:37:50 AM: Decreasing transmit delay: 0 ms
9:38:06 AM: 10% completed
9:38:06 AM: Comm efficiency = 100.0%
9:38:22 AM: 20% completed
9:38:22 AM: Comm efficiency = 100.0%
9:38:39 AM: 30% completed
9:38:39 AM: Comm efficiency = 100.0%
9:38:55 AM: 40% completed
9:38:55 AM: Comm efficiency = 100.0%
9:39:13 AM: 50% completed
9:39:13 AM: Comm efficiency = 100.0%
9:39:31 AM: 60% completed
9:39:31 AM: Comm efficiency = 100.0%
9:39:48 AM: 70% completed
9:39:48 AM: Comm efficiency = 100.0%
9:40:05 AM: 80% completed
9:40:05 AM: Comm efficiency = 100.0%
9:40:24 AM: 90% completed
9:40:24 AM: Comm efficiency = 100.0%
9:40:41 AM: 100% completed
9:40:41 AM: Comm efficiency = 100.0%
9:40:41 AM: Finalizing upgrade transfer
9:41:17 AM: Installing firmware: 10%
9:41:21 AM: Installing firmware: 20%
9:41:25 AM: Installing firmware: 30%
9:41:29 AM: Installing firmware: 40%
9:41:34 AM: Installing firmware: 50%
9:41:35 AM: Installing firmware: 60%
9:41:43 AM: Installing firmware: 70%
9:41:52 AM: Installing firmware: 80%
9:42:01 AM: Installing firmware: 90%
9:42:20 AM: Installing firmware: 100%
9:42:40 AM: Firmware installed successfully
9:42:40 AM: Device restarting...
9:42:40 AM: Disconnecting ethernet connection
9:42:40 AM: Ethernet connection disconnected
9:43:40 AM: Attempting to reconnect ethernet connection
9:43:40 AM: Ethernet connection reconnected: []
9:43:41 AM: Upgrade Power Cycles = 1
9:43:42 AM: Upgrade completed at Friday, August 23, 2024 9:43:42 AM
9:43:42 AM: Processing file: PM8000_webpages_V004.005.000.zip
9:43:42 AM: Web update started at Friday, August 23, 2024 9:43:42 AM
9:45:01 AM: Upgrade completed at Friday, August 23, 2024 9:45:01 AM
9:45:01 AM: Restoring framework C:\Users\xxx\Desktop\Config Files\78-1R.dcf
  • ION Setup
  • PM8000
mjr5097
Crewman mjr5097
Crewman
Posted: ‎2024-10-07 04:26 AM
The LED indicator is flashing red/green.  Meter is being replaced.
Mehran_Mehrnia
Admiral
Posted: ‎2024-08-29 11:47 AM . Last Modified: ‎2024-08-29 11:49 AM
Hi @mjr5097
It seems the upgrade process is almost done except restoring Framework as I do not see 'Framework restored successfully' statement at the end of the Upgrade log.
Did you power cycle the meter and see if it can be reached?
Meter has the Status/Power LED, please check if it is solid green after power cycle or flashing Red/Green.
If it is flashing Red/Green, means startup or firmware upgrade sequence is in progress or likely meter is stuck in the boot loop. In this case, when there is no communication with the meter, unfortunately the only option is replacing the meter.
Best Regards,
-Mehran
L3 Expert tech Support Specialist
Charles_Murison
Posted: ‎2024-10-04 02:15 PM
Hello @mjr5097 ,
Any follow up on this topic?
Were you able to paste the template?
Charles
mjr5097
Crewman mjr5097
Crewman
