Continue
  • My Subscriptions
  • Events
RVC
Metering & Power Quality
  • EcoStruxure Power & Grid
  • RVC
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
Gladwin
Gladwin Contributor
Contributor
Posted: ‎2024-10-06 02:08 AM
1368
RVC
Good day Team,
Kindly assist on this ,
How can I active these two loggers for RVC on other meters ?
We tried these instructions as per manual still didn’t get it right .
https://product-help.schneider-electric.com/PowerLogic-ION9000/en-us/content/09-pq/configuring-advan...
  • ION9000
Mehran_Mehrnia
Champion
Posted: ‎2024-10-06 11:39 AM
Hi @Gladwin
You have not specified the type of "other meters" since RVC(Rapid Voltage Change) feature is not available on all ION meters which is dependent on feature set(Essential, Standard and Advanced). For example, PM8000 and ION7400 with Essential feature set does not support RVC.
Pleas not that, if the RVC feature exists and is enabled, but still does not log values, chances are during an RVC event, if the RMS voltage exceeds either the Swell Lim or Sag Lim registers, the RVC event is discarded and the event becomes a sag or swell.
Best Regards,
-Mehran
L3 Expert Advanced metering
Charles_Murison
Champion
Posted: ‎2024-10-07 09:19 AM
Hello @Gladwin ,
Some context may be required here. As Mehran said, only certain meters support RVC, not just the meter type but also the firmware version may play a role. If the meter has an old version of firmware, the RVC may not be supported.
On the assumption that the meter does support RVC, what happens when you set the Enable RVS to true?
Charles
Mehran_Mehrnia
Champion
Hi @Gladwin
Best Regards,
-Mehran
Charles_Murison
Champion
Hello @Gladwin ,
Charles
