Continue
  • My Subscriptions
  • Events
PM5563 IP Range Problem
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM5563 IP Range Problem
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
Sven_Ortmann
Sven_Ortmann Leader
Leader
Posted: ‎2018-11-14 10:42 PM . Last Modified: ‎2018-11-16 12:00 AM
1142
I do have problems setting an IP adress with in the END 255
e.g. 192.168.254.255
This could not be set and the meter sends an error "unsupported Ip Range"
In the documentation the range is defined from 0-255
The customer is well known in the network technologie and says this is a very old ip range (only 0-254) and should be adopted in the firmware.
Anything to do because this could be a possible drop out criterium!
thank you.
Romain_Polette
Romain_Polette Champion
Champion
Posted: ‎2018-11-22 06:33 AM
Hello @Sven_Ortmann
As discussed on bFO, currently there is no possiblity to attribute this kind of IP addresse to the PM55xx.
I have also discussed this topic with @Anonymous user.
Maybe we can have the help of @kumaresh to better understand the use case and see is something can be done.
Romain POLETTE
Solution Architect - France Operations
