PM5560 device log export
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM5560 device log export
Charles_Murison
Picard Charles_Murison Picard
526
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
138
Ramasamy_N
Captain Ramasamy_N Captain
115
Veronika1
Ensign Veronika1
Ensign
Posted: ‎2022-03-29 02:44 PM
2540
Hi everyone! I hope you're doing well.
I need to establish a point-to-point connection between my PC and a PM5560 to export the logs. But I think I'm not filling out the HTTP parameters properly. When I try to press the HTTP TEST button, I get this message:  HTTP test with errors. Check settings.
Thank you for helping me to solve this problem.
Best regards.
  • ION Setup
  • PM5000
Charles_Murison
Posted: ‎2022-04-18 08:40 AM
Hello @Veronika1 ,
Strongly recommend you contact your local tech support team and start a case to troubleshoot,
Charles
Replies 8
Charles_Murison
Hello @Veronika1 ,
Charles
Cake
Ensign Cake
Ensign
Posted: ‎2024-08-02 03:05 AM
1575
Hello Veronika
This problem can be resolve? Could you please share for solution.
Charles_Murison
Posted: ‎2024-08-02 08:51 AM
1556
Hello @Cake ,
What firmware version of PM5560 do you have? Many versions do not support log export.
Charles
Cake
Ensign Cake
Ensign
Posted: ‎2024-08-02 09:01 AM
Charles,
Thank you for your reply. Could you please tell me about how to check and update firmware? I don't see it in manual. And I might be check on Monday.
Cake
Ensign Cake
Ensign
Posted: ‎2024-08-04 08:54 PM
1505
Hello again @Charles_Murison
I already upgrade firmware the version is 2.7.4 but still cannot export data log.
Is something wrong with setting?
Charles_Murison
Posted: ‎2024-08-06 11:00 AM
Hello @Jesus_Diaz ,
Do you know what versions of firmware support data log export on PM5560 meters.
Charles
Jesus_Diaz
Lt. Commander Jesus_Diaz Lt. Commander
Lt. Commander
Posted: ‎2024-08-09 09:46 AM
Hi @Cake,
Have you tried a direct connection to the meter? Have you tried using another laptop or temporarily disabling antivirus/firewalls? If it still doesn't work, I strongly suggest contacting your local tech support team to start a case for troubleshooting.
In FW 2.7.8 to 2.9.9 in PM5560, webpage limitations were introduced due to cybersecurity concerns. In FW 4.0.0 and above, most of the limitations were removed. However, the data log and data log export features have not been restored yet. This should be fixed in an upcoming FW release, but I cannot provide a timeline yet. The current FW 2.7.4 you have should have this feature enabled.
Jesus Diaz
DedySuhendra
DedySuhendra
Cadet
Posted: ‎2024-09-25 12:55 AM
try this setting
