PM5500 Issue
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • PM5500 Issue
Charles_Murison
Charles_Murison Champion
566
Mehran_Mehrnia
Mehran_Mehrnia Champion
194
Ramasamy_N
Ramasamy_N Champion
115
user4567
user4567
Explorer
Posted: ‎2024-10-12 03:14 AM
1667
PM5500 Issue
I have a PM5560 meter, and when I power it on, it only shows the Schneider logo without displaying any other parameters. The screen remains unchanged, and while the LED light at the bottom is on, it's not blinking. What could be causing this issue?
  • PM5000
  • PowerTag Energy
Jesus_Diaz
Jesus_Diaz Mentor
Mentor
Posted: ‎2024-10-18 08:00 AM
In that case, I would strongly recommend reaching out to your local support team.
Jesus_Diaz
Jesus_Diaz Mentor
Mentor
Posted: ‎2024-10-15 12:23 PM . Last Modified: ‎2024-10-15 12:23 PM
Hi @user4567,
Please check if the control power supply is within the range according to your meter. Is this a new meter?
When did this issue start?
Do you know the current firmware it is running? Maybe you can check on the meter's label.
I would suggest reaching out to your local support team.
JD
user4567
user4567
Explorer
Posted: ‎2024-10-17 09:45 PM
1604
Yes, control supply is within range. Meter is not new, it was working fine before, but suddenly this issue started occuring. When i try to update firmware, it does not detect the rs485 port.
Jesus_Diaz
Jesus_Diaz Mentor
Mentor
