Continue
  • My Subscriptions
  • Events
PM5350 error
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM5350 error
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
Ken_Hsu
Ken_Hsu Mentor
Mentor
Posted: ‎2016-08-16 09:00 PM
2886
PM5350 error
Hello all
I have a customer using PM5350. The meter recently showed the "wrench" signal, and the hex error code is 0021.
The user manual states that the "wrench" signal indicates that the meter requires attention. However, I couldn't find any information on the error type.
Is there an error code document that can explain the meaning, and what actions to take?
Thank you ~~
Tags (3)
  • error code
  • pm5350
  • wrench
sesa52700
sesa52700 Leader
Leader
Posted: ‎2016-08-18 11:55 AM
2846
Hello Ken,
I checked with our technical team. The error code information is available in Register List (Address 20003 - user notes - bitmap format). . In this case, 0021 hex error code specifies, the measurement input signals are exceeding the direct input limits. Ensure that the connection is within the specified limits for the measurement signal. In the Troubleshooting section of the user guide, it recommends that if maintenance wrench is lit, you should contact tech support and give them the error code and any event messages.
Go to [Maint] > [Diag]. Event messages
display to indicate the reason the icon is
illuminated. Note these event messages and
call the Technical Support or contact your
local sales representative for assistance.
Margie Myers
Replies 6
sesa52700
sesa52700 Leader
Leader
2846
Hello Ken,
Margie Myers
Ken_Hsu
Ken_Hsu Mentor
Mentor
Posted: ‎2016-08-18 07:43 PM
2846
Hi Margaret,
Thanks for your prompt reply.
I found the 20003 bitmap , as shown below. 0x21 translates to 0010 0001, which corresponds to Bit 01 Summary and Bit 06 Clipping Detected are turned on.  Is that correct?
0 = OK, 1 = Error Detected
Bit 01 = Summary
( on if any other bit is on - Maintenance Icon shown on HMI )
Bit 02 = RAM Failure
Bit 03 = NVRAM Failure
Bit 04 = RTC Failure
Bit 05 = Calibration Failure
Bit 06 = Clipping Detected
Bit 07 = Over-Running Energy Pulse Output
Bit 08-16 Not Used
I assume that "Clipping Detected" indicates that input measurements signals are exceeding the direct input limits. Does it differentiate between voltage and current?
In addition, is there a document that gives a more detailed explanation of the error codes?
Thank you~
sesa52700
sesa52700 Leader
Leader
Posted: ‎2016-08-19 08:12 AM
2846
Hi Ken, I'm checking again with the technical team for answers to your follow-up question, but perhaps a call to tech support would get you an answer quicker than in this Exchange. The good thing about calling tech support is that the question gets logged as an FAQ and the topic can be searched in the CCC (Customer Care Center) FAQ database. I've sent an email to the offer manager to let him know your request for better documentation on error messages.
Margie
Ken_Hsu
Ken_Hsu Mentor
Mentor
Posted: ‎2016-08-20 11:59 PM
2846
Noted.
Thank you Margie.
Your replies we're most helpful.
Ken
sesa52700
sesa52700 Leader
Leader
Posted: ‎2016-08-22 07:19 AM
Ken, here is the response. He may contact you directly.
Hello Margie,
Please refer my replies in bold.
Hi Margaret,
Is that correct? - Yes, Correct.
Bit 01 = Summary
Bit 08-16 Not Used
Does it differentiate between voltage and current?  -There is no differentiation between voltage and current signals.
- No.The customer should contact the Schneider tech support team as customer will not be able to act on it expect clipping and over run pulse output errors.
I will make a note about possibly improving our error code documentation. Thank you for the feedback!
Margie
odowaa
odowaa
Explorer
Posted: ‎2024-11-20 05:30 AM
I am using pm5350, I have a problem display,   my device backlight  is getting weak ,  if I change backlight timeout or even screen timeout  still my backlight is weak
