Continue
  • My Subscriptions
  • Events
PM5350 Modbus register 2034? "CT Location for 1 or 2 CT Metering" ?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM5350 Modbus register 2034? "CT Location for 1 or 2 CT Metering" ?
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Posted: ‎2021-04-22 03:13 PM . Last Modified: ‎2024-01-30 04:44 AM
2
2509
An old PM5350 has been setup 3ph, 4w, Wye Grounded, 3CT,VT Direct Connect. The Modbus register 2034 has been modified from default (1) to (2). After investigation (CT ratio OK), I suspect that this register give us wrong a reading.
I cannot find any documentation anywhere else than in the register list : 2034 Modbus register  "CT Location for 1 or 2 CT Metering".
How to write on this register ? it seems like there is no access either from ION setup or the front panel...
How much this register affects the current/power/energy calculation of the meter ?
Thanks for your help,
Olivier
Description   Register Units Size
(INT16)
Data Type Access Range Default NV User Notes
CT Location for 1  or 2 CT Metering   2034 --- 1 INT16U RWC 1 – 3 1 Y If 1 CT, value is meter terminal connected
If 2 CT, value is meter terminal not connected
1 = Phase A, 2 = Phase B, 3 = Phase C
  • PM5000
Tags (2)
  • Modbus Register 2034 CT location
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2021-04-27 04:10 AM
Hi Olivier,
This register 2034 is used only in the 1 CT or 2 CT configurations.
When we select the number of CTs connected as 1 then here we need to specify in which location that CT is connected.
​When we select the number of CTs connected is 2 then here we need to specify in which location the CT is not connected and kept open.
Also these values will not be considered in 3P4W or 3P3W configuration where we have 3 CTs are connected.
Ramasamy N
Charles_Murison
Champion
Posted: ‎2021-04-26 11:20 AM
@Ramasamy_N any ideas to this question?
Charles
Ramasamy_N
Ramasamy_N Champion
Champion
Hi Olivier,
Ramasamy N
