Continue
  • My Subscriptions
  • Events
How to correctly use Transformer Line Loss Calculation?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • How to correctly use Transformer Line Loss Calculation?
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
PowerLogic
PowerLogic ION8650 series
mauricio_rojas_
mauricio_rojas_
Explorer
Posted: ‎2021-04-27 04:25 AM . Last Modified: ‎2022-10-19 01:44 AM
1797
We have a client that wants to use the TLL option from an ION8650 meter. using:
https://community.se.com/t5/EcoStruxure-Power-Monitoring/How-To-Setup-Transformer-Line-Loss-Calculat...
The client has configured the meter using the attached guide but they wonder why the load profile is stopped when the TLC is ON (Attached picture).
After this, please we ask for your support:
1. IS the client configuring the TLC correctly?
2. How to see the data that is configured in the TLC?
Thanks in advance.
https://app.box.com/s/3gpia0v44jl7d1zibtg0wtyyb5em28iq
  • Thumbnail of PowerLogic ION8650 series
    PowerLogic
View products (1)
  • ION8000
Charles_Murison
Champion
Posted: ‎2021-04-27 09:05 AM
Hello @mauricio_rojas_ ,
A few points, KVA rated = 0?  I believe there is a calculation somewhere in the TLL calculations that takes a square root of (X-Y) if X < Y, then result is a complex number that will return N/A from Arithmetic module. This N/A will propagate until the data recorder.
To troubleshoot with newer version of ION Setup with advanced configuration, this you can start at the Data Recorder module, if you right click the input you can get a popup ("Go to X") to navigate to the module where input is coming from. This will take you to the output of the module in question, from here you can go to the input of the upstream module and repeat until you find the source of the N/A.
Charles
Charles_Murison
Champion
Charles
