I have several PM5300s and it has been years since I initially set them up and now I have a new SCADA system to read them.
1. Are there firmware updates for these devices?
2. I cannot get the modbus driver to read them. I have tried some simple modbus/tcp tools, but can't seem to read registers. I am assuming it is just the standard port 502.
3. Do I need a device ID or any other designator?
GDB
Hello @geoffrybrown
1. Have a look at https://www.se.com/ca/en/product-range/61281-powerlogic-pm5000-power-meters/#software-and-firmware the firmware for your meter type, note that PM5300 have a number of different versions, PM5310, PM5330, PM5331, PM5341 etc. Be sure to use the correct firmware version for your meter type.
2/3. For the PM5320 and PM5340, the Modbus TCP device ID is 255. https://www.se.com/ca/en/faqs/FA341569/
Charles
1- As always you can check the SE website for the latest firmware version. For example, the PM5320 and PM5340, which are Ethernet-based:
2- Inside the firmware package, you will find the latest Modbus Map that needs to be used in 3rd party software or any standard Modbus reader. Correct, the default Modbus TCP port is 502.
3- If you are polling Modbus data via TCP, the device ID is 255.
Best Regards,
-Mehran
L3 Expert Advanced Metering
You're welcome.
Here is the list of DLF-3000 Error Codes that could occur during firmware upgrade when communicating with devices through an Ethernet/Gateway:
https://www.se.com/ca/en/faqs/FA232730/
515: MODBUS + gateway path unavailable
Please make sure the device is accessible to the PC where DLF is running and port 502 is open.
Best Regards,
-Mehran
L3 Expert Advanced metering
Hi @berzek
Best Regards,
-Mehran
Hello @geoffrybrown
Charles
Best Regards,
-Mehran
Thank you both for your help. So I was able to use the Modbus Tester to validate and was able to get Ignition to talk to it. However, there has always been network issues with these devices and in looking through the firmware notes, I saw that there was an update to the ethenet stack. So I wanted to update.
I went and found the DLF-3000 software and the 2.4 update from the Schneider site. However, when I ran to connect, I got a Device Error = 515 and I haven't been able to find anywhere where it says what that was. I finally broke down and called Schneider today and they didn't know what that error was either and they said they would get back to me.
You're welcome.
Best Regards,
-Mehran
Do you observe the same behavior after power cycling the meter?
The image shows the meter type as PM5300 series. There is a FAQ regarding 'PM53XX Meter Front Display Freezing and Communication Loss' that could help but I would recommend contacting the local tech support team for further assistance and investigations.
Best Regards,
-Mehran
hallo @Mehran_Mehrnia in the latest DLF-3000 v3.3 we cannot enter Ethernet MODbus ID# of 255 as the max supported ID# is 247, obviously if i try ID#1 it fails with Device Error 515 as expected.
any suggestions there ?
Hi @berzek
Best Regards,
-Mehran
Thanks @Mehran_Mehrnia , that worked wonderfully, good to know the way to go, afik, i did not find that procedure in any FAQ for the DLF-3000.
Confirm, that it works as described by @Mehran_Mehrnia
