Continue
  • My Subscriptions
  • Events
PM5000 Ethernet port removable?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM5000 Ethernet port removable?
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
RobGraham
RobGraham Champion
Champion
Posted: ‎2025-01-29 12:48 PM
1394
I have a strange question.  At a customer site, I found a PM5000 meter where the Ethernet cable had come out, taking the plastic portion of the port with it.  Nothing seemed obviously broken, and we were able to slide it back in to restore communications.  However, it didn't click in or anything, and I suspect the next time the enclosure door is opened, it will fall out.
My question is, is this component supposed to be removable?  Is there some way to get the port to stay in that we didn't find, or should I advise them to replace this meter?  I'm starting to question many PM5000s over the years that have failed to communicate.
Thanks for your help!
  • PM5000
Jesus_Diaz
Jesus_Diaz Leader
Leader
Posted: ‎2025-01-30 10:19 AM
1358
Hi @RobGraham,
The PM5000 series Ethernet port is not removable. Perhaps the cable was forcibly pulled out without pushing the Ethernet cable tab down, which may have caused part of the port to be damaged.
Without pictures, it is hard to suggest a solution, but if the cable cannot stay in place properly or if the customer is concerned about it, then the meter will need to be replaced.
JD
Replies 4
Jesus_Diaz
Jesus_Diaz Leader
Leader
1358
Hi @RobGraham,
JD
RobGraham
RobGraham Champion
Champion
Posted: ‎2025-01-30 10:34 AM
That's exactly what I was looking for.  Thanks for your help!
Yarom
Yarom Troubleshooter
Troubleshooter
Posted: ‎2025-07-14 01:08 AM
986
I happened to come across this post while looking for something completely different.  I happened to have the same issue at a VIP Datacenter client with a dozen PM5560 per site (3 sites). Two of them had the plastic portion of one of the RJ45 ports come off as well.
Is this then a manufacturing defect?
I had to replace them but did not go with a TEX. Should we have done so? Could I just send pictures without shipping back the products for a TEX?
Best regards,
Yarom
Charles_Murison
Champion
Posted: ‎2025-07-14 08:47 AM
Hello @Yarom , for a TEX to be completed, the device would need to be returned to the factory for analysis.
Charles
