Continue
  • My Subscriptions
  • Events
Meter Selection
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Meter Selection
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
sesa282957
sesa282957 Leader
Leader
Posted: ‎2015-09-18 01:53 AM
1168
Meter Selection
Dear Expert,
Please, i need a meter based on the below specification, kindly select the most appropriate meter.
The following are the minimum technical specifications for the programmable electronic grid energy meters for installation at the Nigerian Electricity Grid/Trading Points-
POWER SUPPLY:
Voltage: -     3x 11000/110V ,33000/110V, 132000/110 and 330000/110V.
Current: -     3 X -/1A           3 X -/1A,      3 X-/5A
Frequency: – 50Hz
System: - 3-Phase 3 wire (or 3-Phase 4 wire for 11,) 33, 132 and 330KV
Secondary voltage variation:  85V—135V
Supply frequency variation           +5%
Internal Battery: -   Lithium CR20255 –1HF or an equivalent giving a total
                             Stand-by life of 10 years (minimum)
Auxiliary Battery: -            Embedded in the meter for down-loading  stored
data during power outage
ACCURACY CLASS
  •   0.2   for 132, 330kv voltage levels and for loads above 50MVA.
  •   0.5   for 11 and 33kv voltage levels.
  • 1.0/2.0 LV, Ring CT Operated- for 415V LV voltage level
  • *MUST BE DLMS/COSEM COMPLIANT - For interoperability with other meter makes, with respect to AMR.
    ENVIRONMENTAL CONDITIONS
    Operating Temp Range:     -        -15oc to 60oc
    Storage Temp Range:        -        -15oc to +70oc
    Humidity: - Annual mean 75% (for 30 days spread over one year, 95%)
    BURDEN
    Voltage Circuit: -                                 1.12W or 2.45VA
    Current Circuit: -                                  /5A Meter 0.12 VA
                                                              /1A Meter 0.02VA
    CASING
    Material:-   The casing shall be for panel or wall mounting with fire retardant type of Bakelite or Polycarbonate.
    Screws: -      All Screws should be stainless steel or nickel – plated brass.
    Current Terminals:                               Screw type 2 per terminal (6mm)
                                                             Cable size: 4.0mm2.
    Voltage Terminals:                                Screw type: 1 per terminal (4mm)
                                                              Cable:  2.5mm2 .
    Auxiliary Terminal:                                Screw type: 3mm
                                                              Cable:  1.5mm2.
    INSULATION
  • 2.0 KV for 1 minute for current circuit
  • 2.0 KV for 1 minute for voltage circuit
  • 4.0 KV for 1 minute for current, voltage, all relay contacts plus auxiliary inputs plus the RS232/485 ports together.
  • 4.0 KV for 1 minute between all relay contacts and the auxiliary input plus communication port (RS232 or RS485)
  • 4.0 KV for 1 minute between one set of relay contacts and the other relay contacts.
    NAME PLATE
    The name plate should contain the following:-
  • Meter serial number
  • Operating current and voltage
  • Accuracy class
  • Frequency
  • Pulse nominal value etc.
    Measured Quantities
  • Import KWH
  • Export KWH
  • Import KVArH
  • Export KVArH
  • Apparent KVA maximum Demand
  • Four Quadrant KVArH
  • Load Profile (180-450days)
  • Line parameters e.g. line voltage, current, power factor, active and reactive power, phase angle, frequency and phase rotation.
    TARIFFICATION:-                    Time of use register
                                          Maximum demand register
                                          Integration period options: 15 min, 30 minutes etc.
                                          Switching times
                                          Seasons times
                                          Billing dates
                                          End of billing dates etc.
    DISPLAY
    The display should be capable of displaying Default, Customer and Utility modes.
    - Battery backup operated display is required.
    EVENTS  MONITORING
    The meter should be able to monitor the following events among others:-
  • Battery fail indication
  • Battery elapse warning
  • Meter fail Indication
  • Reverse run warning
  • Over Current
  • Phase failure
  • Current reversal
  • Voltage reversal
  • Partial demand
  • Meter communication event
  • Time and date of events etc.
    DATA STORAGE
    It should be capable of storing measured quantities as end-month historical values for up to 16 months.
    COMMUNICATION
  • RS232 and RS485 must be fitted as standard
  • Optical port: - Opto – electronic, bi-directional
  • Protocol: -    Flag IEC 62056 - 21 (formerly IEC 61107)
  • Built-in GSM/GPRS Modem with omni-directional antenna
  • Must be compatible with MV 90 AMR Machine for end-month data retrieval.
    SAFETY CLASS
  • Category -    EN61010, EN61011 Class II
    REAL TIME CLOCK
  • Type: - Capable of synchronizing to A.C. Supply or to a crystal
                            Oscillator
  • Accuracy: -    Better than 0.5 of a second per day at 50oC
    ADDITIONAL INFORMATION
  1. The Energy Meters should be taken to a NERC certified Meter Test Laboratory for Type Test and Accuracy Checks, for a fee.
  2. Enough space should be made available on the Control Panel for Mounting of the meters.
  1. The Programming of the meters to the line CT, VT and display sequence should be carried out at the Meter Manufacturer’s Factory for accurate display of billing parameters.
Posted: ‎2015-09-23 02:17 AM . Last Modified: ‎2022-10-18 10:47 PM
Hello sesa282957,
We have the global meter selector app to help you to select meter based on different conditions and applications
Please find more information below:
https://community.se.com/message/67809#67809
