Continue
  • My Subscriptions
  • Events
Is there a CM2000 adapter plate for the PM5500 series devices?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Is there a CM2000 adapter plate for the PM5500 series devices?
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
JohnDell
JohnDell
Contributor
Posted: ‎2024-12-17 03:16 PM
1085
When replacing a CM2000 with a PM5500, using the retrofit kit CM2TOPM5K --
It shows a DIN rail on the back of it. The documentation is lacking info. Is this used to terminate the existing wires and then extend them to the new meter? anyone that has done this--did you have to extend the existing wiring a if so, how did you do it?
  • PM8000
Charles_Murison
Champion
Posted: ‎2024-12-18 07:42 AM
1060
Hello @JohnDell ,
Do the documents in https://www.se.com/us/en/faqs/FA314511/ help you?
Charles
JohnDell
JohnDell
Contributor
Posted: ‎2024-12-18 10:17 AM
Appreciate the reply @Charles_Murison , the doc helps but doesn't illustrate how the existing wiring is extended to the new meter. I'm assuming the DIN rail is intended as a means of terminating and extending it. I've done a few Schneider 85 to 98A conversions which fall into the "extend wiring by whatever means works" category, so will take that approach
Charles_Murison
Champion
1060
Hello @JohnDell ,
Charles
JohnDell
JohnDell
Contributor
