Continue
  • My Subscriptions
  • Events
Is possible to saving the meter dcf by command mode ?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Is possible to saving the meter dcf by command mode ?
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Eddic
Eddic
Explorer
Posted: ‎2017-01-03 09:12 PM . Last Modified: ‎2020-04-22 01:21 AM
1836
People usually saving the meter dcf with ION Setup but is possible to run the ion setup by command mode to doing the samething?
  • ION Setup
Robert_Lee
Robert_Lee Champion
Champion
Posted: ‎2017-01-17 11:03 AM
3
1792
If you are referring to can you save DCF files using the scripting engine, then yes it is possible but requires a high sophistication and understanding on how this is done (and requires some high automation on the part of whatever is creating/issue the scripting text files).
Replies 4
Robert_Lee
Robert_Lee Champion
Champion
3
1792
Eddic
Eddic
Explorer
Posted: ‎2017-01-17 02:23 PM
1792
Thanks Robert.
I am agreed that may need a sophistication on the script, is possible to shared some info to us?
Robert_Lee
Robert_Lee Champion
Champion
Posted: ‎2017-01-19 10:40 AM
1793
If you are already familiar with how scripting works, then you need to use a script function code 3 to "save" a DCF file from the meter followed by the full path to where you wish to save the DCF file to:
Ex. Request1=3,C:\ProgramData\Schneider Electric\ION Setup\Templates\ION8650\ION8650_FAC_V420.DCF
JamesAZZO
JamesAZZO
Leader
Posted: ‎2017-01-20 12:39 AM
Rob - how is that JDX automation stuff going?
