Intermittent Communication Issues with Siemens 9350 ION 7350
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Re: Intermittent Communication Issues with Siemens 9350 ION 7350
Charles_Murison
Charles_Murison Champion
571
Mehran_Mehrnia
Mehran_Mehrnia Champion
202
Ramasamy_N
Ramasamy_N Champion
115
Sepehr_Zarrabi
Sepehr_Zarrabi Troubleshooter
Troubleshooter
Posted: ‎2014-05-29 04:41 PM
1083
We have a customer that has 7 Access 9350 meters (equivalent to ION 7350) on an RS-485 daisy-chain. These are older meters ordered in 2002.
Based on what the customer is saying, this system used to work fine with the ION protocol. However, since they switched everything to ModBus, after roughly 8 hours of communication, 3-4 of the meters drop off-line. Once they are power cycled, they resume communicating. They have tried ProtoNode gateway installed from Siemens as well as Lynxspring BASbridge.
Has anyone seen this type of issue before?
(This is a strategic account. That's why we are trying to help them although they have Siemens meters)
Replies 2
sesa50168
sesa50168 Leader
Leader
Posted: ‎2014-05-29 05:26 PM
1050
Hi Sepehr -
I've not encountered a problem with these particular symptoms, but do know that you should not run ION and Modbus protocol on the same daisy chain.  What software is being used?  There's the possibility that they think they are only talking Modbus, when in fact, there's still some ION protocol being used.
Sepehr_Zarrabi
Troubleshooter
Posted: ‎2014-05-29 10:55 PM
Thank you for the response John.
What I have been told is that they had the WinPM software (equivalent to ION-E). They have decommissioned that software and are now using a Trane BMS. I don't believe they are using the ION protocol anymore.
