ION9000 and PM8000 configuration, order codes and specification
Metering & Power Quality
  • EcoStruxure Power & Grid
  • ION9000 and PM8000 configuration, order codes and specification
Charles_Murison
Picard Charles_Murison Picard
526
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
138
Ramasamy_N
Captain Ramasamy_N Captain
115
boris_grinac
Lieutenant boris_grinac
Lieutenant
Posted: ‎2021-12-07 07:24 AM
3527
is there simple, authoritative, up-to-date specification with ordering numbers and explanation what this order number includes?
Context: I was always using the user manual for this with ordering numbers. But in recent version of the manuals there are unexplained codes in user manual, so I am lost.
  • ION9000
  • PM8000
Charles_Murison
Posted: ‎2021-12-07 05:03 PM
In the manual METSEION92830 is grouped with METSEION92030. The description for METSEION92830 matches METSEION92030 except METSEION92830 for a specific country. (If you cannot order this version, not available in your country) Likewise for METSEION92840 grouped with METSEION92040.
Charles
Sanjeet_Sahota
Lt. Commander Sanjeet_Sahota Lt. Commander
Lt. Commander
Posted: ‎2022-03-03 08:44 AM
We will take a look at making the suggested changes to the technical datasheet in our next major revision.  It has been noted.
- Sanjeet
Replies 6
Charles_Murison
Posted: ‎2021-12-07 11:13 AM
3520
Hello @boris_grinac
Could you expand on the "in recent version of the manuals there are unexplained codes in user manual"? Have you see page 10 of https://www.se.com/ca/en/download/document/PLSED310106EN_Web/
and page 6 of
https://www.se.com/ca/en/download/document/PLSED310058EN_Web/
Charles
boris_grinac
Lieutenant
Posted: ‎2021-12-07 11:33 AM
3516
Hello Charles, thanks for your answer.
Example: in the manual there is unexplained METSEION92830, but this order code is not in technical data sheet. There is also METSEION92840 in user manual, again without comment.
Charles_Murison
Charles
boris_grinac
Lieutenant
Posted: ‎2022-03-02 04:54 AM
3402
Hello Charles,
regarding ION9000 technical data sheet, I have one suggestion, maybe option "20-60 VDC control input" in commercial reference number table should be "20-60 control power input"
Charles_Murison
Posted: ‎2022-03-03 08:06 AM
Hello @boris_grinac ,
I do not have the power to change this but have mentioned your suggestion to offer manager.
Charles
Sanjeet_Sahota
Lt. Commander
- Sanjeet
