Continue
  • My Subscriptions
  • Events
ION76xx and ION73xx Password
Metering & Power Quality
  • EcoStruxure Power & Grid
  • ION76xx and ION73xx Password
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
sesa108084_brid
sesa108084_brid Explorer
Explorer
Posted: ‎2017-08-09 07:39 AM
1190
Good day
Does anyone happened to reset the forgotten password without RMA? We had tried the below but unsuccessful.
Using ION SETUP as below -> FAILED
Please find the way to change the password using Ion setup.
Follow the steps mentioned.
Open ION Setup then go to "diagnostic->trouble shooting ->change front panel password"
Use ION Setup ver. 3.0.14290.03 or Higher
Note that  Default password: 0
In case if this process does not works then unfortunately there is no way to restore the password remotely.
Meters needs to be sent for RMA to the factory.
Note: In case meter will be sent to Factory for RMA , the process will also destroy all the data available in the meters.
Affected Units:
ION 7600
EK-0111A056-01
EK-0307A048-01
ION7350
PC-0208A045-11
PC-0208A046-11
PC-0208A047-11
PC-0208A043-11
Thanks & Regards
EY
Robert_Lee
Robert_Lee Champion
Champion
Posted: ‎2017-08-09 11:25 AM
For the 73xx devices, the front panel password is only for making changes via the front panel (over communications, there is no required password needed to be able to make any changes).
You will likely need to contact Technical Support to open a support ticket and provide device serial #s (which you have posted above) and proof of device ownership after which they will provide individual meter codes to allow you access to reset the front panel passwords assuming you haven't locked out front panel programming.
