Continue
  • My Subscriptions
  • Events
ION Setup can't connect to PM8000
Metering & Power Quality
  • EcoStruxure Power & Grid
  • ION Setup can't connect to PM8000
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Szymon_Hochół
Szymon_Hochół Champion
Champion
Posted: ‎2018-10-10 06:47 AM . Last Modified: ‎2020-04-22 01:08 AM
5889
Hi all,
I have a problem trying to connect to PM8240 using ION Setup. After typing meter's IP adress in browser, the web server works fine, however ION Setup shows an error. I'm using v3.0.18075.02 of the software. Please see the screenshot attached.
Any ideas?
BR
  • ION Setup
Tags (2)
  • ion setup
  • pm8000
Posted: ‎2018-10-10 09:57 AM
5888
Is ION over TCP enabled?
On the webpage: Setup -> Ethernet -> Advanced settings
Replies 6
5888
Szymon_Hochół
Champion
Posted: ‎2018-10-11 06:42 AM . Last Modified: ‎2018-10-11 06:43 AM
It was disabled, turning it back on solved the issue.
Thanks a lot!
BR
Mustafascada
Mustafascada
Explorer
Posted: ‎2023-04-11 03:12 PM
5176
Hi Mr Moreno,
I have a problem trying to connect to PM8240 using ION Setup. After typing meter's IP adress in browser, the web server works fine, ping fine however ION Setup shows nothing I'm using v3.2.2360 of the software. Please see the screenshot attached.
Any ideas?
Charles_Murison
Champion
Posted: ‎2023-04-11 03:47 PM
5171
Hello @Mustafascada ,
Could it be that port 7443 is getting blocked? I noticed that secure ION is enabled on meter. Have you tried to connect specifically on port 7700 or disable secure ION?
Charles
Mustafascada
Mustafascada
Explorer
Posted: ‎2023-04-11 04:27 PM
5167
I've tried to connect specifically on port 7700 or disable-enable secure ION. I'm directly connected to pm8000 with my pc
Charles_Murison
Champion
Posted: ‎2023-04-14 02:28 PM
There could be a few things happening and most are not recommended to troubleshoot over forum. If you need more help I recommend that you contact your local technical support
a) Physical wire broken - Unlikely given you could connect to web page
b) Device blocking connection on port X (possibly visible from front panel or web page)
c) Device connections full
d) Computer blocking connection
e) other
Hard to troubleshoot with forum. Recommend talking to tech support directly.
Charles
