ION Setup & PM5560 issues
Metering & Power Quality
  • EcoStruxure Power & Grid
  • ION Setup & PM5560 issues
Charles_Murison
Picard Charles_Murison Picard
528
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
139
Ramasamy_N
Captain Ramasamy_N Captain
115
sesa99134
sesa99134 Schneider Alumni (Retired)
Posted: ‎2014-12-05 11:26 AM . Last Modified: ‎2020-04-22 01:44 AM
4
1451
Hi Guys, i found some issues trying to read a PM5560 meter using the ION Setup 3.0.14328.01
After to add some aditional channels to the Data Log #1 (like Vavg, Iavg, Power, etc) the obtained data seems to be incoherent. The energy readings are ok but for the another variables they are wrong (lot of exponential and small values).
5387
Using PME the obtained data is OK but using ION Setup seems like ION Setup can´t translate correctly the data obtained from the PM5560 memory.
The following image is the same info but using the PME and Reporter:
5389
Since we will use ION Setup for this kind of applications there is a way to fix this issues on ION Setup?.
Thanks so much in advance.
Best Regards,
Adelmo
  • ION Setup
Replies 4
Robert_Lee
Admiral Robert_Lee Admiral
Admiral
Posted: ‎2014-12-05 04:59 PM
1244
Hello Adelmo,
I've been recently been made aware of this issue and are testing a fix which will be made available shortly.  I'll post again when this is available for download.
sesa99134
Posted: ‎2014-12-09 05:58 AM
Hello Robert,
Thanks so much for your answer, please let me know once you have ready this fix. Thanks!
sesa8515
sesa8515 Schneider Alumni (Retired)
Posted: ‎2015-04-13 01:01 AM
Hello Robert,
any news with this bug? Our customer has the same problem.
Jan
Robert_Lee
Admiral
Posted: ‎2015-04-13 09:32 AM
Sorry I have forgot all about this but it has been fixed for a while now (since build 3.0.14339.1 back in mid December).
You can get the latest version always from the following link:
https://schneider-electric.app.box.com/ionsetuplatest
