ION METER AS SLAVE MODBUS
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Re: ION METER AS SLAVE MODBUS
Charles_Murison
Picard Charles_Murison Picard
495
Ramasamy_N
Captain Ramasamy_N Captain
115
Mehran_Mehrnia
Captain Mehran_Mehrnia Captain
95
Robert_Lee
Admiral Robert_Lee Admiral
92
sesa371309
sesa371309 Schneider Alumni (Retired)
Posted: ‎2015-12-23 09:34 AM
5
2426
i would like  see the  modbus register of my ION 7650 and ION 7500 with EGX300.
I can connect ION 7650 and ION 7500 , also I see their data in supervisor, but when I want see their modbus register I have  some  problems. I have tried view register modbus 40011-40100 .
Message was edited by: JOSUE DANFER SAAVEDRA YANAYACO this is the results of register modbus that is differents .
Replies 5
Yut
Captain Yut
Captain
Posted: ‎2015-12-23 09:45 PM
1
2332
Try to start the address from 40150 it will be Ia,  Va will be at 40166. Try to download  ION_Devices_Modbus_Register_Map.pdf .
The best thing to do, use ION Setup see the actual Modbus map.
JamesAZZO
Sisko | EcoXpert Master JamesAZZO Sisko | EcoXpert Master
Posted: ‎2015-12-24 04:01 AM
2332
What is your application? Seems and combination of devices? Is there no PME?
sesa371309
Posted: ‎2015-12-28 06:57 AM
thansk for suggestions, but  my problem is that I can not  read the  modbus register.
I tried configure my ION7500 /ION 7650  with ION SETUP also.
sesa371309
Posted: ‎2015-12-28 07:12 AM
2332
My application is read modbus register ( read digital inputs,analog inputs) of ION 7650/7500 as slave modbus.The network of device of some enterprises is protocol  modbus to protocol not ethernet .For this I can not use my ION as modbus master and use communication through ethernet.
VictorMarincus
Sisko VictorMarincus Sisko
Sisko
Posted: ‎2016-02-11 01:37 AM
Hi Josue,
Please see the ION7650 User Guide -> "Configuring the Meter as a Modbus Slave".
Then make sure the "Modbus Map Access" is set to Yes in the "Security Options Module" (ref. to ION Reference)
The "Common Modbus Registers - EN" document will give you accurate information about the default modbus registers in our ION meters.
Victor
This is a heading
