Dear Experts,
I hope you are doing well, I'm seeking information about the data traffic generated by the ION 7400 when connected to a platform for real-time monitoring. Specifically, I'd like to know:
Detailed information on these aspects is crucial for evaluating network infrastructure needs in our project.
I would appreciate any additional resources you can share to further understand the data traffic of the ION 7400.
Thank you for your assistance.
Hello @JhimmyJMQT1 ,
Do you have access to https://ecoxpert.se.com/sv/search#keyword/PME%202020%20Daisy%20Chain%20Calculator/tab/documents
If you do not, perhaps you can reach out to your local technical support to see if they can provide you with file.
Charles
This is a bit of a loaded question. A lot will depend on what the ION7400 is connected to. Most of the communication will be poll response. Depending on what is talking to the ION7400 will have a bigger bearing on what the traffic will be like. What protocol are you planning to use? If polling for real time, how often, how much data? Just real time monitoring or onboard logs too?
If onboard logs what is getting logged and how often? Will you read all logs on device or just some? Are you expecting PQ events, if so that is another factor has waveforms are usually included with the PQ events.
Short answer, it depends.
Charles
Hello @Charles_Murison
Thank you for your prompt response to my inquiry. I have added the requested information for your reference.
The client's workflow will involve utilizing both ION Setup and a web application.
Here's a breakdown of their anticipated usage:
With this additional information, is it possible to estimate the approximate traffic that would be used?
Charles
