Continue
  • My Subscriptions
  • Events
IEM3255 - Write to register (function code 16) issue
Metering & Power Quality
  • EcoStruxure Power & Grid
  • IEM3255 - Write to register (function code 16) issue
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
Posted: ‎2022-06-09 12:58 AM
12
8720
I was trying to write CT value (address = 0x7ED, function code: 16 (10Hex)) by Modbus Poll but it doesn't work - I do success to read the registers (frequency, voltage for example without any problem).
The meter connected to my PC by RS485 to USB converter device.
I verified that the "Communication Protection" is disable and the multi traffic is on "By communication".
I used Modbus Poll after it doesn't work with my private gateway board, based linux OS, to make this problem to simple.
When I tried to configure other meter by Modbus writing command - no issue.
Do I need to add termination resistance?
do you have any other idea to solve it? things that I need to verify?
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2022-06-13 04:39 AM
3
8651
Hello @Anonymous user
The Modbus register 2004 to 2036 are the meter setup and status registers and it does not allow to write directly using function code 16.
You can refer the user manual page 40 and above for the Modbus command interface.
https://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=DOCA0005EN-13.pdf&p...
The CT parameter can not write alone, we need to follow the command number 2000 (set wiring command - page 41) using the function code 16 to change the CT primary and secondary along with few other parameters.
Ramasamy N
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2024-07-17 07:36 AM
Please connect with country or local tech support team.
Replies 12
Ramasamy_N
Ramasamy_N Champion
Champion
3
8651
Ramasamy N
Posted: ‎2022-08-01 03:26 AM . Last Modified: ‎2022-08-01 04:48 AM
8474
Hi @Ramasamy_N ,
thanks for your reply.
I implemented code that send one block for all "Set Wiring" registers with one value changing of "CT Primary" to be 6002 (except CT Secondary, since isn't supported in IEM3255) and I got Meter result register ok (Cmd Reg result = 5376 return 0). When I read the "CT Primary" register, it doesn't changed (I verified by reading direct from Meter display).
I sniffed the bus and parse the data - please see the attached files.
I verified that the communication protected is enabled.
Do I need to do some action before I send Modbus set command?
I'm a little stuck with this issue and I would like for any assistance here.
BDY, I also send one block direct from ModbusPoll software to isolate the problem (maybe I have something wrong in my code) and it doesn't work.
many thanks.
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2022-08-01 05:19 AM
8461
The Communication protection must be disabled during the Modbus writing.
Also the refer the attached screenshot of Wireshark traces when we write the set wiring command.
The 24 parameters must filled properly and you can read the CT primary from the register 2030 (UINT16 format).
Ramasamy N
easonkhoh1
easonkhoh1
Explorer
Posted: ‎2024-07-08 09:34 AM
HI, do you mind to share us modbus writing list for IEM3255?
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2024-07-16 01:32 AM
Hi @easonkhoh1
You can find the set wiring Modbus register details from the user manual (page 56)
https://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=DOCA0005EN-14.pdf&p...
easonkhoh1
easonkhoh1
Explorer
Posted: ‎2024-07-16 03:10 AM
6187
@Ramasamy_N , the set wiring keep prompt me 3002 = Invalid Number of Parameters. do you have any solutions?
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2024-07-17 06:24 AM
Hi @easonkhoh1
Can you create the bFO case for this investigation and share the Modbus command structure (2000)?
easonkhoh1
easonkhoh1
Explorer
Posted: ‎2024-07-17 07:25 AM
6134
@Ramasamy_N may i know what is bFO case?
Ramasamy_N
Ramasamy_N Champion
Champion
Kreso
Kreso
Explorer
Posted: ‎2025-12-17 06:23 AM
2852
Could you send us full command syntax for changing CT value in the meter. We are trying without success and need to deploy the Meter as soon as possible.
Thank You with respect.
Kresimir Cosic
Charles_Murison
Champion
Posted: ‎2025-12-19 08:55 AM
Hello @Kreso ,
For a timely response to this request, I recommend you contact your local technical support team as was mentioned in previous post.
Charles
Robert_Lee
Robert_Lee Champion
Champion
Posted: ‎2026-01-13 02:34 PM
Some PowerLogic devices require the programming software to know some meter programming logic in commands being sent.  For example, if Device SysMode is in mode X, and you attempt to modify the CT Primary/Secondary, you may also need to set the I4 CT Primary to the exact same value.  This is why device configuration via communication is not trivial.  I would suggest you attempt to make changes via either the front panel and/or ION Setup and examine the resulting registers post configuration.  This will give you a clue how to alter other registers in the write command (but would be very tedious to figure out all permutations).
