Continue
  • My Subscriptions
  • Events
How can i get a time for store last sag and swell value?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • How can i get a time for store last sag and swell value?
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Ray_Chang_EPEC
Ray_Chang_EPEC
Contributor
Posted: ‎2022-05-25 03:34 AM
1860
Hi all:
I need to get the last sag and swell Voltage value.
And i'm using PME designer for store the value and output it to modbus.
For now I use the diststart as time for store module to store the value of sag.
But the time is not really the sag start time. Can't get the really sag voltage value.
How can I correctly get the last sag voltage volue for V1~3?
Any hint will help. Thanks
  • ION Setup
  • ION9000
  • Power Quality
DanL
DanL Champion
Champion
Posted: ‎2022-05-25 08:21 AM
1854
The disturbance magnitude and duration outputs of the SAG/SWELL module are updated at the 'DistEnd' event.
Much like DRE5 (Sag/Swell Log), you'd want to link the 'Store' input to the 'DistEnd' trigger output.
DanL
DanL Champion
Champion
1854
Ray_Chang_EPEC
Ray_Chang_EPEC
Contributor
Posted: ‎2022-05-25 08:16 PM . Last Modified: ‎2022-05-25 08:53 PM
Hi @DanL
Thanks for reply.
If I use this for store time.
Can it compare with the % that PME's alarm shows? or 9000's on board alarm?
Cause I'm not able to fully create a sag event at my office.
So I'm not sure if the real sag event will make all of this same or close enough.
