Continue
  • My Subscriptions
  • Events
HDMP6000 strange values
Metering & Power Quality
  • EcoStruxure Power & Grid
  • HDMP6000 strange values
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
jcespedes1
jcespedes1
Explorer
Posted: ‎2023-04-19 04:22 PM
6929
Hello, I have three HDMP6000 power meter in my side, one of then works normally, but the others shows strange values. One of then show a lower voltage in some circuits and the other shows low power factor, those strange values affetcs the active power and active energy values.
I searched in the user and installation manual and in the community topics but I couldn´t find what I can do to solve those values. Thanks for any recommendation to solve this problem.
  • Did you know
Replies 9
Madleen_Laclef
Madleen_Laclef Mentor
Mentor
Posted: ‎2023-04-24 07:44 AM
6901
Hello there, looks like something that should be investigated by technical support. Could you please create a CCC case? Thank you.
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2023-04-25 09:04 AM
6886
Hello @jcespedes1
Can you download the configuration file from 3 meters by using the HDPM6000 Manager and share for the analysis? while creating the ticket in CCC.
Ramasamy N
jcespedes1
jcespedes1
Explorer
Posted: ‎2023-04-25 02:48 PM
Hello Madleen, how can create a CCC case?
jcespedes1
jcespedes1
Explorer
Posted: ‎2023-04-25 02:54 PM
6882
Hello Ramasamy, thanks, I share the files in this reply. How can I create a ticket in CCC?
HDPM6000.rar
Charles_Murison
Champion
Posted: ‎2023-04-26 09:31 AM
6854
Hello @jcespedes1 ,
The easiest way to start a CCC support ticket is to use https://www.se.com/ww/en/work/support/country-selector/contact-us.jsp, select your region and country. Some counties use online forum to start, others give email address, and others a phone number. Best to use method for your county.
Charles
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2023-04-27 10:16 AM
6845
Hello @jcespedes1
Thanks for sharing the config fine.
This voltage mismatch seems to be the circuit configuration. Example: Channel 1,3 and 5 are grouped as 1 circuit with 3phase which reads voltage Line to Line and the channel 7 configured as 1phase which reads the voltage line to neutral.
The Power factor mismatch might be due to CT installation. Please verify the actual CT installation in respective phase 1, 2 and 3 and correct if any mismatch like all 3 CTs are installed in any one phase.
Please share following details if above configuration are fine and still the Voltage & Power factor behaviors are not fine.
1.Firmware version for head unit & branch circuit modules.
2.Branch circuit modules details.
3. Screen shot of General settings and channel config tab from meter web page.
Ramasamy N
jcespedes1
jcespedes1
Explorer
Posted: ‎2023-05-04 03:36 PM
6800
Hello Ramasamy,
Thanks for the advice, I changed every circuits fase configuration and one of the meters fixed, but the other keep with stranges voltages values. That else I can check? Add an image of the fail.
Firmware version v1.26.3
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2023-05-05 09:45 AM
6783
Hello @jcespedes1
The shared images are not clear. Is it possible to share the quality images?
Please compare the phase configuration with fixed meter and this meter.
Download the meter configuration file using HDPM6000 manager and share if you did not find any difference during the comparison.
Ramasamy N
jcespedes1
jcespedes1
Explorer
Posted: ‎2023-05-11 06:38 PM
Hello Ramasamy,
Thanks for the advice, I checked the settings between the devices and corrected them but the abnormal values ​​continue in the readings. Attached the image of the failure as well as the backup of the configuration.
SEA012100053 fail.rar
