Continue
  • My Subscriptions
  • Events
Error Setup analog output of Power Meter PM2230
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Error Setup analog output of Power Meter PM2230
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
EasyLogic PM2000 series
Kanon.w
Kanon.w
Explorer
Posted: ‎2025-09-25 11:06 PM
2619
Trying to setup analog output of Active Power for PM2230 in IONsetup. It is giving me error when I send to power meter the parameter.
Following this FAQ Setup analog output of Power Meter PM2230 | Schneider Electric Thailand
I assume the 4mA = 10 kW and 20mA = 100kW
So I want to setup mine as 4mA = 0 kW and 20mA = 600kW
however, it gives me error upon sending to PM2230.
Thank you in advance for your assistance.
  • Thumbnail of EasyLogic PM2000 series
View products (1)
  • ION Setup
Sidharthan
Sidharthan Contributor
Contributor
Posted: ‎2025-09-29 10:46 PM . Last Modified: ‎2025-09-29 10:47 PM
1
2563
@Kanon.w  I tried to reproduce the issue,
Observations:
  1. Once we set the analog output as above and click send, we are getting Invalid Parameter#1 and 2 message in ION setup, but the settings are successfully sent to meter, and analog output is working as the settings.
  2. When we set the Analog Input 1 and 2 to some values and then edit analog output 1 and then clicking send button, the error message is not appearing.
  3. Need to further check with ION Setup team, why it is necessary to setup both analog input and output at the same time.
Sidharthan
Contributor
1
2563
Observations:
Kanon.w
Kanon.w
Explorer
Posted: ‎2025-10-02 05:38 PM
Thanks for the reply Sidharthan, I tried putting in the AI and the error won't pop up anymore but I don't know if it works or not. Is there a way to contact ION Setup team?
Mehran_Mehrnia
Champion
Posted: ‎2025-10-03 10:01 AM
Hi @Robert_Lee
Could you please share your thoughts on this behavior?
Thank you.
Best Regards,
-Mehran
L3 Expert Advanced metering
