Continue
  • My Subscriptions
  • Events
Database doesn't have current values
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Database doesn't have current values
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
sesa433810_brid
sesa433810_brid Leader
Leader
Posted: ‎2017-10-17 09:24 PM
1884
Hi All,
We have a site that using 7.2.3 with Sql Server 2012.
I've noticed that when I query the ION_Data.dbo.DataLog2 table, the data is 9-10 hours behind for all the meters.
Is there a setup, either within the meters (namely PM3255's),  PME Management Console, or ION Setup, where we can define when the data is sent to be logged in the database?
I can query each meter in ION Setup and get real time data. Just can't cross-reference that back to database when it is 9-10 hours behind.
Cheers.
Tags (4)
  • data logs
  • database
  • live data
  • pme 7
Anirban
Anirban Champion
Champion
Posted: ‎2017-10-18 10:50 PM
1854
I believe this is happening because PME always saves all timestamp information in UTC. Is the customer system/server which you are accessing 9-10 behind UTC/GMT?
PME will always time sync a PM3255 device to server local time (PME will time sync a PM5000 series meter to UTC; so it varies from meter to meter depending on meter design). After reading the logs the timestamp will be converted to UTC and then stored in the database.
Tom_Stevenson
Tom_Stevenson Champion
Champion
Posted: ‎2017-10-18 02:36 PM
1854
Hi Russell
I am tying in Anirban DHAR​.  It sounds similar to a firmware/driver issue that was addressed some time ago for the 3255, but I suspect that 7.2.3 (very few of these systems out there) does not have that update.  Anirban DHAR​, can you please confirm?
I am quite sure a move to v8.x will resolve this Russell, but Anirban will be able to confirm first.
Tom
Anirban
Anirban Champion
Champion
1854
sesa433810_brid
Leader
Posted: ‎2017-10-19 05:24 PM
Thank Anirban and Tom,
It was the UTC conversion which threw me out. We are 10.5 hours in from of UTC, so everything is lining up now.
Cheers,
Russ.
