Continue
  • My Subscriptions
  • Events
Comx210 reading PM8000
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Comx210 reading PM8000
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
sesa102217_brid
sesa102217_brid Contributor
Contributor
Posted: ‎2021-08-05 07:59 AM
20278
I have a problem, with Comx210 it is not reading PM8000 meter, but if I select another driver like pm5000 I can read it.
Comx210 is with the latest firmware v6.8.4 and PM8000 v3.0.0
thanks in advance.
  • ION8000
sesa102217_brid
Contributor
Posted: ‎2021-08-11 04:53 AM
 @Charles_Murison  the customer will wait for the next release of meter firmware.
Charles_Murison
Champion
Posted: ‎2021-11-16 08:19 AM . Last Modified: ‎2022-10-19 01:16 AM
17602
Hello @arjan_greenwave  @arjan_greenwave  @sesa102217_brid
Wanted to let you know the latest release of firmware is available to address the modbus N/A exception.
https://community.se.com/t5/Metering-Power-Quality/New-Firmware-version-3-1-0-for-Advanced-Meters-is...
Charles
Replies 18
Tom_Stevenson
Tom_Stevenson Champion
Champion
Posted: ‎2021-08-05 08:56 AM
20270
Hi - what are the communication settings on the PM8000?  Has the protocol been changed from ION to Modbus for the communications port you are using?
Tom
sesa102217_brid
Contributor
Posted: ‎2021-08-05 10:48 AM
20265
I´m using modbus TCP for Comx210 communication with PM8000.
 attached some screens.
Config_Comx210_PM800.docx
Tom_Stevenson
Champion
Posted: ‎2021-08-05 11:14 AM
20259
Are  you able to connect to the device with ION Setup?
sesa102217_brid
Contributor
Posted: ‎2021-08-05 11:17 AM
Yes,
Tom_Stevenson
Champion
Posted: ‎2021-08-05 12:09 PM
20255
There is a Modbus TCP security setting shown in the attached picture - worth ensuring it is on.  Does the ComX indicate whether the connection is successful, but cannot read, or is the connection not succeeding? (There is a setting in the Security Options module to disable read access for Modbus).
Tom
sesa102217_brid
Contributor
Posted: ‎2021-08-05 12:40 PM
20251
I have other meters (iem and pm5560) modbus and modbus TCP already working on this comx210.
Only the PM8000 that was installed now doesn't work, and checking in IONsetup the modbus tcp connection is active.
Tks
Charles_Murison
Champion
Posted: ‎2021-08-05 01:15 PM
20249
Hello @sesa102217_brid ,
Are you able to read the modbus registers using a modbus client like in FA180037 . This would help determine if there could be something on the PM8000 or the gateway to investigate further. While connected to the meter in ION Setup. Switch to advanced configuration -> Security Option Modules -> Security Option module 1 -> Setup registers -> Modbus Map access, Be sure that read or read/write is selected.
Charles
sesa102217_brid
Contributor
Posted: ‎2021-08-06 06:39 AM
20235
Hi, Charles.
Yes,
I can read modbus logs through another client, I used modscan.
Regarding the advanced option, it was read-only and I changed it to read and write, but still no communication.
On the 3rd party protocols Communication screen the default modbus slave is showing N/A.
Do you know if it's normal?
Tks
sesa102217_brid
Contributor
Posted: ‎2021-08-06 06:43 AM
20234
In another test I did, I changed the driver from pm8000 to PM5560 and the readings started to appear,
wrong but communicated.
Charles_Murison
Champion
Posted: ‎2021-08-06 09:01 AM
20227
Having the default Modbus Slave showing "Default" as N/A is normal when there are no custom modbus registers. The PM8000 meters support 3 different configurations, Default only, Default + custom, Custom only.
I do not have a Com'X so I am not 100% sure of the driver. I am wondering if possible that a request to the meter includes registers that are "N/A" inside the meter. For example power factor leading if you have a lag system. If this is the case, 3 options,
1) Wait for the next release of meter firmware (currently under development)
2) If registers in the request are known to always be N/A, it is possible to unlink the registers from the data mapping module in question
3) Place a convert module in front of the data mapping module to convert N/A to either 0 or 1 depending on the need.
4) I am not sure if this is possible, modify the PM8000 driver to not include the N/A registers. Without knowing exactly what the driver is requesting I can't give more specifics. If the driver is doing big block reads, perhaps change to multiple smaller block reads. If already small block reads, either modify blocks to be smaller to avoid the N/A or remove the block completely if not needed.
Charles
sesa102217_brid
Contributor
arjan_greenwave
arjan_greenwave
Contributor
Posted: ‎2021-09-27 06:12 AM
18969
hi,
I have the same problem
Seems that the PM8000 Modbus driver is not working.
When I select PM5560 data is coming through.
Seems like this wasn't resolved?
sesa102217_brid
Contributor
Posted: ‎2021-09-27 06:22 AM
18966
Hi, Arjan.
Not yet, but I created a custom driver for pm8000 on comx210,
if you need me let me know that I'll forward it to you.
Send e-mail for me.
arjan_greenwave
arjan_greenwave
Contributor
Posted: ‎2021-09-27 06:31 AM
arjan@greenwave.co.za
Thank you will appreciate it!
Romain_Polette
Romain_Polette Champion
Champion
Posted: ‎2021-09-27 06:32 AM . Last Modified: ‎2022-10-19 01:24 AM
18962
Hello @arjan_greenwave ,
I have the same behavior on my Com'X510 v6.8.4:
  • PM8000 v2.1.0 is working fine with the native Com'X model
  • ION9000 v3.0.0 is not working as expected with the native model
Issue is related to the current FW Version 3.0.0 of the PM8000 / ION9000 platform. Things will not change until next release of PM8000 FW release (no date confirmed yet). This is not planned to update the ION native models to change the Modbus Registers polling method.
You can try to apply the workaround provided by Charles above or in the following thread:
https://community.se.com/t5/Metering-Power-Quality/The-Value-of-quot-N-A-quot-register-of-PM8000-fir...
Or also create a custom PM8000 driver mapping the register you want to log and publish.
Romain POLETTE
Solution Architect - France Operations
Charles_Murison
Champion
17602
Charles
Romain_Polette
Champion
Posted: ‎2022-02-09 01:53 AM . Last Modified: ‎2022-10-19 01:07 AM
15688
Hello @Charles_Murison ,
It seems that the upgrade to v3.1.0 do not fix the issue with the Com'X.
Update on the following thread:
https://community.se.com/t5/Gateways-and-Energy-Servers/PM8000-predefined-model-for-COMX210-fw-6-8-4...
Romain POLETTE
Charles_Murison
Champion
Posted: ‎2022-02-09 08:29 AM
Hello Romain,
Randi was able to test with a Com'X and did not have trouble connecting to PM8000 and reading values.
Charles
