Analog output channel 1&2 0-20mA ports giving 36mA
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • Analog output channel 1&2 0-20mA ports giving 36mA
Charles_Murison
Charles_Murison Champion
566
Mehran_Mehrnia
Mehran_Mehrnia Champion
195
Ramasamy_N
Ramasamy_N Champion
115
sanjeev4_kumar_
sanjeev4_kumar_ Explorer
Explorer
Posted: ‎2018-01-30 10:17 PM
1146
It was observed that ION 7550 MD controller to Power Logic (Schneider)  SCADA values were freeze,We have reset the power supply of the meter after that analog output channel 1&2 0-20mA ports giving 36mA and this will effecting the our load shedding program.
Please advice for the solution and reason why we are getting analog output as 36 ma.
Bojan
Bojan Leader
Leader
Posted: ‎2018-01-31 02:39 AM
Hi Sanjeev,
I had a similar problem with PM8000 meter optional Input / Output card (“I/O card”) which supposed to be a bad contact issue:
I would suggest you to re-install the optional Input/Output card (“I/O card”) by following the Installing the I/O Card steps from ION7550 / ION7650 I/O Card document.
Best Regards,
Bojan
Tom_Stevenson
Tom_Stevenson Champion
Champion
Posted: ‎2018-02-21 10:14 AM
Sanjeev - is this resolved?
Tom
DanL
DanL Champion
Champion
Posted: ‎2018-02-27 02:38 PM
I'm interested in learning more about both cases (since they have completely different designs):
1. What device or devices are in the analog loop?
          what are the differential and common mode load impedances
          what is the differential voltage at the analog output terminals of the =S= device
          what is the voltage to earth at each of the analog output terminals of the =S= device
2. how was the 36mA DC measured? IE. value from =S= output device, clamp on DC meter, voltmeter across series load resistor, etc
3. Does powercycling the meters resolve the issue?
4. Does disconnect + reconnect the analog loop resolve the issue?
