"No license for LonWorks communication" error message in Classic Network
  • "No license for LonWorks communication" error message in Classic Network
  • CraigEl
    CraigEl
  • sesa145087_brid
    sesa145087_brid
  • Anonymous user
‎2018-09-07 03:32 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 07:11 PM
When trying to view values in a Classic Network, "[No license for LonWorks communication]" message shows up in the Value tab and the alarm window.
TAC Vista
Vista Classic Network
Though you are using Classic network, it's still using LON standards. You still need the license for TAC Vista Server. If the Server license is missing or invalid, you will get this kind of message.
Check your license file and make sure you have the server license included. The server license should look something like listed below:
INCREMENT Vista.Server taclic 5.1 permanent 1 ISSUER=TAC \
If you do not have the line above, it means you do not have the proper license for TAC Vista server. Thus, you get the error message saying "No license for LonWorks communication."
The solution is to purchase the TAC Vista Server license, or use the demo license or an engineering dongle.
Related Articles:
  • "No license for LonWorks communication" with TAC Vista Server LE
  • "No license for LonWorks communication" error when using a non LE dongle
  • "No license for LonWorks communication" - LonMaker Recovery Folder
  • "No license for LonWorks communication" Error in Windows 2008 Server X64
  • "No license for LonWorks communication" in Vista Workstation
  • TACOS startup delay utility
  • 4049
0% helpful (0/1)
