What are the PinOuts for the RS-232 Connection of the older 1st Generation CX controllers.
  • What are the PinOuts for the RS-232 Connection of the older 1st Generation CX controllers.
  • RandyDavis
    RandyDavis
  • ScottLeedberg
    ScottLeedberg
  • Chris_Asbury
    Chris_Asbury
  • AdamSteele
    AdamSteele
  • PaulFr
    PaulFr
  • Alan_Wood
    Alan_Wood
‎2018-09-07 12:18 PM
Last Updated: Guinan RandyDavis Guinan ‎2022-08-10 08:05 AM
What are the PinOuts for the RS-232 Connection of the older 1st Generation CX controllers to connect through Hyper terminal.
Andover Continuum
  • Hyper Terminal
  • Continuum CX Gen 1 CX9900
  • Continuum CX Gen 1 CX9940
  • Continuum CX Gen 1 CX9400
  • Continuum CX Gen 1 CX9410
  • Continuum CX Gen 1 CX9200
Need to direct connect to a first-generation controller to configure its IP address and ACC Net ID.
The Hyper Terminal cable needs to have the below pinouts.
RJ Connector - - - - - - - - - - - - - 9 Pin RS-232 PC
Controller Comm3
Pin 1 - DTR - - - - - - - - - - - - - Pin 6 - DSR
Pin 2 - CTS - - - - - - - - - - - - - Pin 7 - RTS
Pin 3 - CXD - - - - - - - - - - - - - Pin 1 - CXD
Pin 4 - RTS - - - - - - - - - - - - - Pin 8 - CTS
Pin 5 - GND - - - - - - - - - - - - - Pin 5 - GND
Pin 6 - RD - - - - - - - - - - - - - Pin 3 - TD
Pin 7 - DSR - - - - - - - - - - - - - - Pin 4 - DSR
Pin 8 - TD - - - - - - - - - - - - - - Pin 2 - RD
On the RJ connector for the controller's comm3, Pin 1 is the furthest to the left with the insert clip facing away from you and the gold teeth facing you (download drawing).
For the CX9200 and CMX controllers download the pinouts here.
Download Command Terminal Reference Guide here
Tags (4)
  • 4447
  • ChrisAsbury22
  • hyperterminal
  • netcontroller
100% helpful (1/1)
