Setting the IP address of a Xenta 5/7/9xx through serial communication
  • Setting the IP address of a Xenta 5/7/9xx through serial communication
  • CraigEl
    CraigEl
  • Cody_Failinger
    Cody_Failinger
  • Sacco
    Sacco
‎2018-09-07 02:25 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 03:50 AM
How to set the IP address of a Xenta 5/7/9xx through serial communication.
Satchwell MicroNet, TAC INET, TAC Vista
  • Xenta Servers
  • Xenta 511, 527, 555, 701, 711, 721, 731, 913
If the IP address of a Xenta 5/7/9xx is not known initially, then no configuration can be done through the IP interface. The IP address must be set through serial communication.
[video]
IP setup for a Xenta server (Xenta 5/7/9xx) through serial communication for step-by-step instructions for this process.
Labels (3)
  • Satchwell MicroNet
  • TAC INET
  • 2838
