Text Output through RS-232 Port in I/NET
  • Text Output through RS-232 Port in I/NET
  • Roger_Bently
    Roger_Bently
  • CraigEl
    CraigEl
‎2018-09-07 02:58 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 10:33 PM
Utilize the RS-232 port to send text out to a third party device such as CCTV
TAC INET
I/NET Seven
Integration Assistance
This V-Doc describes the way text output can be set up in I/NET to be sent out to third party hardware such as CCTV through the RS-232 port.
The port that will be used for this application cannot be one that is already being used by the serial port section, A/C reader port, or printer port in the peripheral section of the configuration profile.
For the guide of integration with Pelco analog matrix, refer to How to integrate I/NET with Pelco Analog Matrix.
  • TAC INET
  • 3002
