Regional settings might differ when TAC Vista server runs as a service
  • Regional settings might differ when TAC Vista server runs as a service
  • MathiasBj
    MathiasBj
  • CraigEl
    CraigEl
  • Cody_Failinger
    Cody_Failinger
‎2018-09-07 01:21 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 09:01 PM
Regional settings might differ when TAC Vista server runs as a service.
TAC Vista
TAC Vista Server set to run as a service
If TAC Vista Server is configured to run as Windows service it might have different regional settings. This is because the TAC Vista server service needs to be configured to use a specific user account (See Registering/Unregistering TAC Vista Server as a Windows service). One common symptom would be that the date and Time stamp might have another format.
To make sure that TAC Vista server is using the correct regional settings:
  1. Log on to the system once using the credential that TAC Vista server is configured to use
  2. Check the regional settings for this account.
  • 3076
