MSDE and Windows 7
  • MSDE and Windows 7
  • Tom_Poovey
    Tom_Poovey
  • Roger_Bently
    Roger_Bently
  • CraigEl
    CraigEl
MSDE and Windows 7
‎2018-09-10 12:27 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 06:18 PM
Installing I/NET on a PC using MSDE and MSDE won't start.
TAC INET
  • I/NET Version 2.40 and above
  • Windows 7
  • MSDE
MSDE does not run on Windows 7.
If the user has attempted this, more than likely the OS has corrupted SQL. There are a couple of things that can be done as described in Verify in Windows Registry all items are deleted after uninstall of I/NET Seven and MS SQL. However to return the PC to its original state the best bet would be to reinstall the OS, or a backup prior to the installation of I/NET.
  • TAC INET
Tags (2)
  • 5794
  • inet
