Verify in Windows Registry all items are deleted after uninstall of I/NET Seven and MS SQL
  • Verify in Windows Registry all items are deleted after uninstall of I/NET Seven and MS SQL
‎2018-09-07 01:12 AM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:38 AM
After an uninstall of I/NET Seven and MS SQL, you might verify in the Windows Registry that all the items were deleted.
Having issues installing I/NET what can I look for.
TAC INET
I/NET all 2.4X versions
Warning
In some cases when re-installing, installing I/NET after a failed attempt or upgrading I/NET you may want to start fresh. After an uninstall of INET Seven and MSDE if items remain in the registry they will cause issues with future installations.
  1. Go to the bottom Task Bar and choose the “Start” button.
  2. Select the “Run” option and enter “Regedit”
  3. Once in the Windows registry go to “HKEY_CURRENT_USER, if the “CSI” entry is present delete this entry
  4. While still in the HKEY_CURRENT_USER look in the Microsoft File Folder for any “SQL” entries and remove them if they are present.
  5. Minimize the HKEY_CURRENT_USER folder and open up the HKEY_LOCAL_MACHINE File Folder, if the “CSI” entry is present delete this entry.
  6. While still in the HKEY_LOCAL_MACHINE, go to the Microsoft File Folder and look for any “SQL” entries. If you find any delete then from this file folder.
Caution:  Before editing the SQL registry items you should ensure that no other software using SQL is still installed - all software that is installed should be uninstalled prior to modifying any registry entries.
See also, MSDE and Windows 7.
  • TAC INET
Tags (3)
  • 2992
  • pc
  • removal
