Lost/Forgot/Modify the SysAdmin SQL default password created during the installation of TAC Vista 5.X.X in typical mode
  • Lost/Forgot/Modify the SysAdmin SQL default password created during the installation of TAC Vista 5.X.X in typical mode
  • CraigEl
    CraigEl
  • PeterLarsen
    PeterLarsen
  • RobertAndriolo
    RobertAndriolo
  • Sampath_Konda
    Sampath_Konda
‎2018-09-10 06:26 PM
Last Updated: Guinan RobertAndriolo Guinan ‎2022-11-07 06:56 PM
Lost/Forgot/Modify the SysAdmin SQL default password created during the installation of TAC Vista 5.X.X in typical mode.
TAC INET, TAC Vista
  • TAC Vista 5.x.x
  • SQL 2005 Express
  • Microsoft SQL Server Management Studio Express:
    (http://www.microsoft.com/download/en/details.aspx?id=8961)
  • Local Admin rights Required.
Procedure if SQL Password is Lost/ Forgotten or Modification required.
  1. When you click on Microsoft SQL Server Management Studio Express, it will open the below page and require you to choose the way you want to log in: either by “Windows Authentication” or “SQL Server Authentication”.
    • If you want to log in using Windows Authentication, choose this option and go in. (It uses the Windows login credentials).
    • If you want to log in using SQL Server Authentication, choose this option and enter Login and password.
  2. If you want to change this Login and Password:
    1. Enter using the Windows Authentication
    2. Choose Security > Logins > Select the login ID
    3. Right click and go to Properties
    4. Change the password and re-login using the new password.
Below is an example where the password for the login 'sa' has been changed:
Labels (2)
  • TAC INET
Tags (2)
  • 5390
  • PeterLarsen22
