License Administrator error "EXITING DUE TO SIGNAL 28 Exit reason 5"
  • License Administrator error "EXITING DUE TO SIGNAL 28 Exit reason 5"
  • RandyDavis
    RandyDavis
  • JohnBoehmer
    JohnBoehmer
  • CraigEl
    CraigEl
  • sesa150561
    sesa150561
‎2018-09-06 09:19 AM
Last Updated: Administrator CraigEl Administrator ‎2021-09-20 06:26 PM
The License Server is not working and may show Vendor Daemon Down errors. The LMadmin log shows the error. LicenseEngine (taclic) exited with status 28
TAC Vista
  • Vista
  • License server
Data Execution Prevention (DEP) is activated.
Antivirus or other software can scan/use the port used by the vendor daemon.
If the time drifts over two minutes and a time synch occurred, the vendor daemon can stop.
https://support.citrix.com/article/CTX137111
  1. First, check that DEP is not activated.
  2. Make sure that there is no antivirus program that has portscan activated
  3. Make sure there is no other software that uses the same port as the vendor daemon
  4. Make sure that the time does not drift too much, if the time drifts two or more minutes and then a resynch occurs the vendor daemon can stop
This is more likely on VMware where time synch can occur from either the domain or VMware tool. Check Windows event log (Security) for time synch messages.
NOTE: It can also appear just by stopping the server manually.
Labels (2)
Tags (4)
  • 17209
  • CraigEllis21
  • JohnBoehmer21
  • Vendor Daemon Down
