Incompatible SQL Server Version error when Restoring I/NET Database in DBCreate
  • Incompatible SQL Server Version error when Restoring I/NET Database in DBCreate
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • sesa145087_brid
    sesa145087_brid
‎2018-09-11 07:04 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 09:47 PM
When restoring database, an error will show up, saying that version is incompatible with this server.
EcoStruxure Building Operation, TAC INET
I/NET
This is usually caused by restoring new SQL database to older version or under different kind of Operation Systems (like restoring a 64 bit database to a 32bit SQL server). Microsoft doesn't like to do this.
There is build number matrix for each SQL server version:
  RTM (Gold, no SP) SP1 SP2 SP3 SP4
SQL Server 2012 11.00.2100.60 11.00.3000
SQL Server 2008 R2 10.50.1600.1 10.50.2500 10.50.4000
SQL Server 2008 10.00.1600.22 10.00.2531 10.00.4000 10.00.5500
SQL Server 2005 9.00.1399.06 9.00.2047 9.00.3042 9.00.4035 9.00.5000
So check the build number in the error message and download the corresponding version of SQL to restore and be used for I/NET.
Refer to How to Troubleshoot on DBCreate for more issues about DBCreate.
Labels (2)
  • TAC INET
  • 15835
