How BACnet controllers are established as being Online / Offline
  • How BACnet controllers are established as being Online / Offline
  • CraigEl
    CraigEl
  • Cody_Failinger
    Cody_Failinger
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-06 09:47 AM
Last Updated: Administrator CraigEl Administrator ‎2025-08-13 05:47 PM
How are BACnet controllers established as being Online / Offline?
BACnet
BACnet controllers may appear offline in the system, even though they can still be communicated with. This raises questions about how their online/offline status is determined.
The online/offline status of BACnet devices is managed by the BACnet device manager plugin, which processes BACnet I-Am messages to maintain a device table.
The following rules and mechanisms are used to determine the status of BACnet controllers:
Device Discovery and Initial Probing
  • When a new device is discovered, an entry is added to the device table.
  • The system probes the new entry up to four times at 5-second intervals.
  • If the device does not respond within this time, it is declared offline.
Offline Detection via MSTP Driver
  • Building Operation uses the MSTP dev driver to monitor token passing.
  • If three consecutive tokens are missed, the device is marked as offline.
Probing Offline Devices
  • Once a device is offline, the system sends a Who-Is message every 60 seconds.
  • Offline devices are probed indefinitely at 60-second intervals until they respond.
  • Online devices are never probed.
Status Transition
  • A device is considered online once it responds to a request.
  • If it fails to respond, its status is updated to offline, and probing resumes.
Tags (2)
  • 15273
  • CraigEllis25
0% helpful (0/1)
