HID PIN Pad reader for I/NET Part Number
  • HID PIN Pad reader for I/NET Part Number
  • Cody_Failinger
    Cody_Failinger
  • sesa139513
    sesa139513
  • CraigEl
    CraigEl
‎2018-09-10 07:45 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 08:42 PM
HID PIN Pad reader for I/NET Part NumberHID PIN Pad reader for I/NET Part Number
TAC INET
I/NET Access Control
HID PIN Pad reader for I/NET and which part number to use?
iPortal shows several PIN pad readers from HID (HID-6136CKD000214 HID-6136CKD000009) but only one works with I/NET.
Here is a pdf document which helps to explain which part number works with I/NET. The 09 means the 8 bit blast which is required for compatibility.
Want to use Pin Pad only without using the proxcard? The RK40  will do Prox only or Prox + Pin but not Pin only. See Essex Pin Pad Reader programming for Pin Only or for higher security Pin Only see Code-Guard Scramble Pin Pad Reader Programming.
  • TAC INET
  • 7491
