Essex Pin Pad Reader programming
  • Essex Pin Pad Reader programming
  • Cody_Failinger
    Cody_Failinger
  • Tom_Poovey
    Tom_Poovey
  • CraigEl
    CraigEl
‎2018-09-10 06:14 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 06:21 PM
Essex Pin Pad Reader Programming in I/Net Seven.
TAC INET
Any Windows OS Version and I/Net Seven Version
Need to program an Essex Pin Pad reader in I/Net Seven.
Here is the link to programming the Essex Pin Pad Reader
Essex Pin Pad requires the site is not using Large Numbers
The Essex Pin Pad is for site which wish to use Pin only for entry. Not Pox Card + Pin or Prox only. For information on a Prox card access which includes Pin Pad see HID PIN Pad reader for I/NET Part Number. For a higher security Pin Only option comparable to the Essex see Code-Guard Scramble Pin Pad Reader Programming.
  • TAC INET
  • 7476
100% helpful (1/1)
