Graphics Editor will not open and causes a font related error
  • Graphics Editor will not open and causes a font related error
  • sesa139513
    sesa139513
  • Derrick_Ratliff
    Derrick_Ratliff
  • Benji
    Benji
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-11 04:57 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 07:22 PM
When attempting to edit a graphic through WorkStation, the Graphic Editor crashes with the following message:
"Font xxxxxx does not support style xxxxxx"
Building Operation Graphics Editor
Font
When a Graphic object is edited, the editor does not open and an error message is presented, this error is caused because the font is missing.
Dependant on the Windows operating system in use, the process for confirming that the "Tahoma  Regular" font is missing will vary.
Windows XP
Open the Control Panel and select "Fonts" and confirm that the font is missing.
Windows 7
Select the Windows button and then search for "Font". Choose "View Installed Fonts" and review the fonts to see if Tahoma - Regular is available.
If this font is missing, then copy it from another PC, download it, or visit http://support.microsoft.com/kb/314960 which deals with adding / removing fonts.
If Workstation is crashing when you see this error, please see WorkStation crashes when opening some TGML graphic pages following a Windows update.
  • 13574
