Differences between EcoStruxure Energy Expert and EcoStruxure Power Monitoring Expert
  • Differences between EcoStruxure Energy Expert and EcoStruxure Power Monitoring Expert
  • David_Kendrick
    David_Kendrick
  • Cody_Failinger
    Cody_Failinger
  • BillNeville
    BillNeville
  • DavidChild
    DavidChild
‎2020-12-06 11:50 AM
Last Updated: Admiral David_Kendrick Admiral ‎2023-04-26 03:27 AM
There can be confusion on the differences between EcoStruxure Energy Expert (formerly Power Manager) and EcoStruxure Power Monitoring Expert (PME)
EcoStruxure Building Operation, Other
  • EcoStruxure Energy Expert (formerly Power Manager)
  • EcoStruxure Power Monitoring Expert
Power Monitoring Expert (PME) is a long-established product in the Schneider Power (EMS) offer and so its place in the market is well known and its support path is very clear.
Energy Expert is a much newer offering that intentionally sits nearer to EcoStruxure Building Operation (EBO) in the BMS community, while still remaining an EMS product and so its place in the market and support path is more easily confused.
Definitions
Schneider Electric's supervisory software dedicated to power monitoring that enables you to maximize operational efficiency, optimize your power distribution system, and improve bottom-line performance
Schneider Electric's premier building management system (BMS) providing integrated monitoring, control, and management of energy, lighting, HVAC, and fire safety.
EcoStruxure Energy Expert (EE)
Designed to offer Power Monitoring Expert (PME) features to new and existing EcoStruxure Building Operation (EBO) projects, giving extra capabilities to manage power utilization in a BMS environment.   It utilizes EcoStruxure Web Services (EWS) to be able it to share data between the two EcoStruxure software platforms. (EBO and EE) and applications such as the ETL Tool and the Integration Utility in the integration process.
The Schneider Electric standard for sharing data among various Schneider software platforms to facilitate the creation of EcoStruxure Solutions. Based on conventional Web Services technology (SOAP, WSDL)
ETL Tool
The function of the ETL is to extract select historical data (Trend logs) from EBO, and load that data into the Energy Expert SQL database for use in Dashboard and Reports etc.
Integration Utility
The function of the Integration Utility is to export Energy Expert Dashboards, Reports and Alarms for import into EBO to enhance its Power Offer to the customer
Product Support Path:
PME, Energy Expert, ETL and the Integration Utility are are all fundamentally Power Products and so should always be raised through your local Product Support Team (via your Customer Care Center (CCC)) under an EMS commercial reference. However in cases where an Energy Expert project needs specific assistance with the EBO side of the integration then a BMS commercial reference should be used instead.
Labels (2)
  • EcoStruxure Security Expert
Tags (3)
  • 18121
  • DavidKendrick20
  • DavidKendrick23
80% helpful (20/25)
