Delete LonWorks Device Templates
  • Delete LonWorks Device Templates
  • CraigEl
    CraigEl
  • RobertAndriolo
    RobertAndriolo
  • sesa139513
    sesa139513
  • Derrick_Ratliff
    Derrick_Ratliff
  • PaulFr
    PaulFr
  • Cody_Failinger
    Cody_Failinger
  • Zhenting_HU
    Zhenting_HU
‎2018-09-10 11:17 PM
Last Updated: Picard RobertAndriolo Picard ‎2023-02-20 05:14 PM
Delete Lonworks Device Templates
  • Building Operation Automation Server
  • LonWorks devices
Some templates are preloaded with the software; if the particular device does not have a supplied template, you can upload an XIF file. This is done by selecting File/LonWorks import/Device Template and then importing the XIF from the manufacturer.
An unused Device Template causes no harm to the system; however, there may be a desire to remove a Device Template.
EBO 3.x and later
Device Templates can be added and deleted in all device types using the Resource Manager - Device Templates tab
SBO 1.x and  EBO 2.x
Device Templates cannot be directly deleted from Building Operation WorkStation, however, they can manually be deleted from the  Enterprise Server file system. When a device template is imported, you should understand if the template should be located in the Enterprise Server or an Automation Server.
  1. If the device template is located in an Automation Server, it can only be removed by upgrading the Automation Server using the Device Administrator (you can stay with the current release).
  2. If the device template is located in an Enterprise Server, it can be removed using the following process.
    1. Locate the template path in the Building Operation database (e.g., C:\Documents and Settings\All Users\Application Data\Schneider Electric StruxureWare\Building Operation 1.3\Enterprise Server\db\UDT\public\public\lon\devicetemplates) Note: in newer releases, the path has changed slightly, e.g., For V1.8.1:
      C:\Documents and Settings\All Users\Application Data\Schneider Electric StruxureWare\Building Operation 1.8\Enterprise Server\db\UDT\pu\public\lon2\devicetemplates
    2. Delete the two template files named Pidxxxxx, where xxxxx are the numbers or letters in parenthesis behind the device template's name visible in WorkStation.
    3. After deleting the templates, you may need to restart the Enterprise Server.
Tags (6)
  • 12075
  • CraigEllis23
  • PeterLarsen22
  • PeterLarsen23
  • remove
  • replace
50% helpful (1/2)
