Database size limitation and recover options on a Single User system in Continuum
  • Database size limitation and recover options on a Single User system in Continuum
  • Cody_Failinger
    Cody_Failinger
  • ScottLeedberg
    ScottLeedberg
  • Alan_Wood
    Alan_Wood
  • CraigEl
    CraigEl
‎2018-09-07 12:45 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 01:52 AM
Is there a limitation to the size the database can be on a Single User system in Continuum?
Andover Continuum
  • Single User Continuum system
  • MSDE database
Microsoft has put a limitation in the size of the MSDE database. Once you hit this limitation your Single User Continuum system will not operate properly.
The size limitation is 2 Gb.
It may be possible to recover after hitting this limit by removing un-needed log entries from the database, but this is not always a guarantee you will be able to recover the database.
Another way to recover from this is to back up the database, if you can, and restore it to standard SQL installation. From this point you can remove any unwanted logs and shrink the database. Then you can back up the database and restore it back to the Single User system.
Another way to recover from this is to back up the database, if you can, and restore it to standard SQL installation and convert the Single User system to a LAN installation.
Finally if all the above do not work for your system you will have to restore from the last known good backup of the database.
See Microsoft Database size Limitations and Continuum for SQL Express information.
Tags (3)
  • 2577
  • gig
  • recovery
