ACCDataServices Crashes on Startup or During Operation in Continuum
  • ACCDataServices Crashes on Startup or During Operation in Continuum
  • Alan_Wood
    Alan_Wood
  • Cody_Failinger
    Cody_Failinger
  • ScottLeedberg
    ScottLeedberg
‎2018-09-07 06:04 AM
Last Updated: Administrator CraigEl Administrator ‎2025-11-24 02:11 PM
ACCDataServices crashes when starting CyberStation or during normal operation.
Andover Continuum
  • CyberStation
  • Windows permissions issues
  • Windows Firewall configuration
  • Mixed CyberStation versions (e.g., 1.94 and 1.94 SP1)
  • Heavy resource usage on standalone systems
  • Third-party BACnet devices flooding trend logs
  1. Step 1: Software Updates
    • Do NOT mix 1.94 and 1.94 SP1 CyberStations on the same database
    • Install CyberStation 1.94 SP1 or greater
    • 2.03 is the most current version and
    • Upgrade controller firmware to the most recent
    Step 2: Installation Requirements
    • Ensure user has Local Admin rights during CyberStation installation.
    • Turn Windows Firewall OFF during installation. (Open ports
    • Disable VirusScan software during installation (Turn on during normal operation)
    Step 3: Event Notifications
    • Avoid unnecessary recipient options (Pager, Log, Forward, etc.) to reduce traffic.
    • Check enhanced alarm delivery in Database Initialization > Server (or Stand Alone).
    Examples of unnecessary recipient options
    Step 4: Action-Object Mapping
    Ensure each Event notification action (e.g., Display Graphic) has a corresponding object for point alarming.
    Step 5: Stand-Alone Cyberstation Systems
    • Heavy resource usage when extended logging, graphics, SQL Server, CyberStation run together can contribute to errors
    • Eliminate Windows error log issues and disable certain functions like graphics to see if that feature contributes to the errors
    • Consider server-class PC for demanding sites
    Step 6: Third-Party Devices
    • Disable/unplug 3rd party BACnet devices or disable their trend logs
    Step 7: Liebert Sitelink
    • Versions 1.93 and below: Bacnet trendlogs may affect Continuum by flooding data
    • Upgrade to 1.94 or greater and disable trend logs
    Step 8: Diagnostics
    • Run acctrace, Continuum error log, Windows application log and Wireshark to detect errors.
    • Use Windows application logs, system info
    Reference Article: Top 10 Steps for Troubleshooting Cyberstation and webClient issues
Tags (7)
  • 4405
  • accdataservices
  • AlanWood24
  • AlanWood25
  • crash
  • cyberstation
  • event notfication
