Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
Posted: 2023-05-18 02:09 AM
Is PoE on field equipment uncommon?
I need to set up an industrial Ethernet switch, but I'm not sure if we'll use PoE for field devices in the future. We currently do not use any.
Thank You.
Posted: 2023-06-08 09:29 PM
I use various laser profilometers & cameras as PoE. I also on occasion will use a PoE splitter to get power to a non PoE device which is nice if you want to minimize what's running through a drag chain or robot dress pack. It's a nice to have right now definitely not a need to have. One last thing make sure maintenance understands PoE and has spares for injectors, switches, and splitters
Posted: 2023-06-12 01:52 AM
PoE is starting to appear on the valve actuators (re:SP90), power is needed to be injected every 7 to 10 devices. Specific cables are used to connect and daisy chain devices, IP water ingress protection is partly the reason for the specific cables.
