Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
Posted: 2024-11-25 07:20 AM
Hello there,
A consultant reaching out with a question, what is the suggested maximum length of tubing/hose used for differential pressure measurement? Commercial Reference: EPU305LCD
Thanks for any help!
Regards.
Posted: 2024-11-26 06:18 AM
Discussed internally and got following feedback:
Its a "rule of thumb" recommendation not based any testing of this.
The general guidance is to keep the runs of tubing as short as possible to maintain accuracy and response time. I would recommend tubing no longer than 100 ft for best performance.
However, if longer distances are required, the customer should validate the performance of a single unit prior to committing to a full build.
